跳转到主内容
The MCH-108 Digital Multimeter is sold by iFixit.
What is the accuracy of the device?
Hey all!
I've been eyeing the market for a digital multimeter and I'm definitely interested in this model, but unfortunately there aren't any technical specifications listed on the store page for the product. I just wanted to know if anyone knew what the accuracy of this model is? (i.e. To how many decimal places can this model measure confidently)
Thank you for your help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
@star75733 The MCH-108 is a USD$20 multimeter. A meter like the MCH-108 will work well enough for basic operations like resistance, current, DC voltage and AC voltage. Tell us how many decimal points you need in your measurements and we might just find you the right one.
For any further information, I suggest you contact iFixit directly via email support@ifixit.com and see what they can tell you.
这个答案有帮助吗?
得分 0
7条评论:
Hey I appreciate your response!
I think 5 decimal points would be more than sufficient although I could live with 4. Thank you again for your reply!
完成的
@star75733 just out of curiosity, what do you measure that requires 4 decimal places?
完成的
To make what would probably be a longish story short, I am assisting in university research lab that is synthesizing and testing various materials for use as electrodes in electrochemical cells and I've been wanting to take some samples home to tinker with them you could say.
The equipment at the University is excellent, but alas I personally don't have have much equipment, so I just want something that will produce measurements with some degree of accuracy in line with the data from the lab.
Since I've never bought this kind of equipment before though I'm just looking for some guidance to get a decent product for a reasonable price.
完成的
@star75733 ok, got it. Great choice. Again, the iFixit staff can most certainly provide the biggest help on this! Good luck with your tinkering and your research!
完成的
As an electrician I would say that a new multimeter should always be measured beside one that does what you want. The digital ones have adjustments inside that allow you to calibrate them.
完成的
显示更多的2条评论
添加一条评论
最有帮助的答案
Inside the back cover onec you've removed it you should see a potenmeter use a plastic screwdriver. Test and adjust , test and adjust beside a meter you know to be calibrated or test something that you know the exact value of and see what yuh need to do.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
star 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 47
总计 1,342
