My Laptop was off when my small rabbit wizzed on it. What should I do?
My Intel MacBook Pro A1286 was not plugged in when my very small rabbit wizzed on the left top of my keyboard. What must I do? I am too scared to turn it on now!!
First remove the battery if you haven't already. Then open it up as much as you can and clean up the mess. You need to remove the urine as that will be very damaging to the electronics. After cleaning and drying prop upside down and let dry for several days before trying to turn it on. If you feel uneasy about any of this take it to Apple now. Good luck and if anyone has other ideas feel free to jump in. Ralph
这个答案有帮助吗?
I have removed the battery immediatly...and held it upside down...and urine came out...and then left it outside in the shade,were it was windy for couple of hours..
Majesty's suggestion of using isopropyl alcohol is a good one. I agree with him. Ralph
Thanks for your Quick Response
++ for the battery suggestion, completely slipped my mind.
DO NOT POWER IT ON!!!.. If possible remove the topcase and use q-tips with isopropyl alcohol to rid of excess moisture and store the machine in a bag with rice if possible. You have done right by not powering it on. You can search here under "liquid Spill" or "water damage" for more ideas from other posts. I would not power it on for a few days, even after the clean-up.
这个答案有帮助吗?
Hi there, The Qtips isopropyl alcohol...where can I buy it? Yes!! It was not plugged in at that time...and never did after the accident...and the big problem is not to plug it in for few days...The comp. is my work!!!!
You can get isopropyl alcohol at any grocery store or pharmacy. Just make sure you don't get RUBBING alcohol as that has a higher water concentration.
I understand your situation but being hasty in this situation can cost you a beautiful machine. Just be patient and you'll have a higher chance of successfully saving your machine.
NOTE: the isopropyl alcohol and q-tips are two separate products.
Ok..Thanks will keep you up to date!!!
Ok, good luck!!!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,770
6条评论
Can any body help please!!!!
由 Nolte 完成的
wow... that's quite an interesting situation.
由 Josh Calvetti 完成的
Well, at least it was a small rabbit....
由 rdklinc 完成的
Here's a link for the rabbit: http://www.cooks.com/rec/search/0,1-0,de...
由 mayer 完成的
Lmao, that's too funny Mayer, but I think that was what I would of done with the furry friend after that incident. LOL
由 Majesty 完成的
显示更多的1条评论
