In cpc power supplying is not coming
In cpu power supplying is not working
@devika14103 checked the power supply by disconencting the power supply from the motherboard. Then place a jumpoer between the green wire and a black ground wire. Since we do not know exactly what power supply plug you have, it will help if you post a picture of it with your Question. We can then show you where to place the jumper. 在已经存在的问题里加入图片
If it does not work, you know you have a bad power supply. If it does work you need to check the power button as well as the motherboard.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 60
