跳转到主内容
加入维修社区 - 创建账户
Is my iMac dead?
iMac G4 17 800 MHzEMC1936
Hi I've got an iMac G4 17" it's been unplugged for a year. I'm trying to get it running again but now it won't do a thing.
I've had the lead checked and that's ok, opened it up and reset the PMU, replaced the battery (and reset the PMU again), but each time no joy and absolutely no response.
Does this mean the power unit needs replacing or the logic board ? Or could it be something much simpler, there's never been any hint of anything wrong with the computer before.
Considering binning it once I've taken out the hard drive.
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My g4 did the same thing just had it fixed and it was the power supply unit inside I did reset and replaced battery and nothing so I'm betting it's the same problem
完成的
添加一条评论
1个答案
已选择的解决方案
Since you've opened it up check that all connections securely and correctly reconnected to the logic board. If a connection is bad pressing the start button might do nothing.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
phillip naylor 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 1,829
