跳转到主内容
加入维修社区 - 创建账户
DualShock 4 CHU-ZCT2U 的维修指南、手册和故障排除帮助。获取自己维修 DualShock 4 CHU-ZCT2U 所需的一切。
R2 Trigger not responding at all
Hey guys! So I've had my DS4 for about 6 years now. I didn't use it for a while (about 2 years), and when I plugged it in the other day (I use it on PC, my PS4 doesn't work) the R2 trigger wasn't responding at all. It's not a flicker or a "I have to press real hard" thing: it's completely dead.
I opened the controller to check for any obvious signs (broken plastic, something missing, something burnt), but honestly couldn't find anything. I even took it off and tried pressing the sensor myself and nothing (I did the same with the L2 trigger to compare, and it responded perfectly). I used DS4Windows to test the buttons' response.
So that's the extent of my "knowledge", I don't know electronics enough to really know what's wrong other than what I did. Is there anything else I should be checking? Like something in the motherboard, or maybe a cable/flex I don't know about? I didn't take the battery off to expose the motherboard because I wouldn't know what to look for before asking.
I don't have the money to buy a new one right now (plus the rest of the controller works perfectly), and would like to avoid sending it to a "technician" to be charged a lot for something I could fix myself.
Thanks in advance for reading and any help you can provide!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
1个答案
已选择的解决方案
I got super nosey about the answer to this. I am not a controller expert, but it sounds like you need to do some more teardown. Most of the signals for buttons are carried by a huge flexible sable that surrounds the frame the board is attached to. This is a picture of the front part of the trigger. The blue cable is what ultimately sends the button signals to the controller's board. It could be something isn't quite aligned properly, or the cable is damaged.
这个答案有帮助吗?
得分 3
2条评论:
Thank you for your answer! So I took your advice and opened it up all the way: I cleaned the board front and back, the flex cables, the plastic frame with the flexible that's shown in your picture (mine's green, but it's basically the same one), and pretty much every nook and cranny with isopropyl alcohol and q-tips. Unfortunately, the trigger's still dead, the rest of the controller still works perfectly.
Do you have a recommendation in terms of trying to figure out whether the problem comes from the board or the flex frame? I'm guessing the only next step is replacing something, but I'm still not sure where the problem lies and I don't really know how to figure it out.
Again, thank you for your answer!
完成的
Did you ever find a solution to this?
完成的
添加一条评论
添加你的答案
wasivis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 81
总计 4,219
