My laptop is not starting charging
@mobilezone8947 start off with the simple things. First you want to check your power supply. Make sure it has the proper voltages. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. After that you need to check and see if your motherboard even gets power. For that of course, you need to open it up. This teardown Packard Bell EasyNote TK87-JO-050PL Teardown can help you with this. Post Some good pictures of what you see. That way we can see what you see 在已经存在的问题里加入图片
You should also consider replacing the battery. A depleted battery can no longer be charged.
指南
难度:
非常容易
2 - 5 minutes
指南
难度:
中等
10 minutes
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 119
