跳转到主内容
加入维修社区 - 创建账户
Nokia 3 的维修和拆解信息。Nokia 3 是一款于 2017 年 6 月发布的 Android 智能手机。其型号为 TA-1032、TA-1020、TA-1028 和 TA-1038。
Power button is not working
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi Sushil,
Assuming you've exhausted all the possible software remedies (reset/wipe/restore/etc.) then there are only about two other things that can go wrong with the power button. There is the actual physical button you put your finger on and push, and under that is the electro-mechanical part consisting of a circuit board with a domed metal contact that makes the electrical connection when the button is pushed.
Either part can cause problems, but fortunately both are replaceable. Here's a guide showing you how to replace the circuit board.
Manuales / Nokia 3 / Side push buttons
There's a different guide just for the physical buttons here.
Manuales / Nokia 3 / Volume and power keys
The parts themselves are readily available; for example here's the circuit board.
ZONBEMA Side Key Button For Nokia 3 Volume Side Power Switch on off Button Key Flex Cable Replacment Parts - AliExpress
这个答案有帮助吗?
得分 1
添加一条评论
Well check out this video: https://www.youtube.com/watch?v=Ks4TWFuP...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SUSHIL TUDU 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 26
总计 852
