跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
798 个问题 查看全部
Battery Connector broken, must change logic board?
I repaired the LCD but while i was re-mounting the iPod i broke all the pints of battery connector (it worked pretty well for 1 hour) Any Help? what can i do? thanks guys. I want to repair this iPod because i'm sentimentally attached to it.
Byehttp://imageshack.us/photo/my-images/694...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
ruggeromariazanolini, that is a very common thing to happen. Anyhow, there are really only two things that you can do. One is, of course, to replace the logic board. Not a very expensive or difficult task. The other thing you can try, is to get a local shop to solder a new connector onto the board. It is surface mounted, so you will need to get someone with experience in doing that type of repair. The clip is available at places like this. Either one of those repairs will ensure that you get to keep your iPod functioning. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
4条评论:
Thanks mate. I understand, so you think is possible to change that connector(with the new one you've shown me) though the small pins are completely broken? i'm going to a tech expert right now, thanks 4 your timely response :)
完成的
ruggeromariazanolini, yes it is possible to get it fixed. Just remember that this is a surface soldered connector and requires special skills and tools. Good Luck and let us know.
完成的
Tomorrow i'll have some news about it. Thanks really a lot, you've been really kind! =)
完成的
Good Luck to you and let us know how it works out.
完成的
添加一条评论
HI the charging connector 3 path is damaged how to solve this someone recomended puting jumper but unable to find the right track
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ruggeromariazanolini 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 2,168
