跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 个问题 查看全部
Vizio TV Troubleshooting: No Standby Power
Vizio E55-C1. No standby power, no picture, no sound.
Problem occurred last summer and am just now getting around to attempting to fix it. Bad storm blew a transformer near our house. After repairs TV worked fine for a few hours. Turned it off and never came back on.
Utilizing a multimeter, I have determined:
-Power from cord to power board
-Continuity through the fuse
-12V Power to main board
If I am reading the key right, Pin 8 should be my 5V standby but I have no volts. There also isn't a wire in the connector for the 5V pins...
No obvious signs on damage on any of the boards.
Based on all my research, I am leaning toward replacing the power board but am hoping for some direction before I start throwing parts at it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@ronaldbresett strange that you have the 12V but not the stby voltage. This"There also isn't a wire in the connector for the 5V pins..." is even stranger :-) It does sound like the power board being the issue but lightning strikes most commonly takes out the main board. Post a couple of good pictures of your boards with your Question. That way we can see what you see and hopefully we can have a good outcome of this repair.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
10条评论:
Thanks, just realized my images didn't embed. Original post should be updated.
I'm hoping I've missed where the standby voltage should be at but don't see any other low voltage pins labled.
完成的
@ronaldbresett check the PS On pin. Check as is and then check when you try to turn the power on.
完成的
PS On has 2.99V constant. Also checked the BL- Off / On Pin 0.09V.
Pressing the power key did not change voltage readings
完成的
@ronaldbresett 3V is pretty normal for that circuit and usually when the set turns on, it goes high for a short time. It actually sounds like your power board is not doing to bad. Keep in mind that it is your main board, that tells the power board to turn the rest of the TV on (simplified of course). The 5V on your power supply could very well be for another Vizio TV model. They use a hodgepodge of parts and are sometimes tough to follow.
On your T-Con board (the blue board) there should be a fuse labeled F101. Can you check that a. for voltage and b. for continuity?
完成的
OK Continuity jumps around from. 1 to -.70ish. F101 bounces around 0.5V.
Didn't think of that (being used for another model). So glad I didn't pull the trigger on the power board already. Was thinking I was missing something with the Standby Power.
Thanks alot for walking me through this!
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Ronald Bresett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 165
