What is code p1491
my honda accord has the check engine light the code is p 1491
alain soto, DTC P1491: EGR Valve Insufficient Lift Usually caused by a bad EGR valve, the solenoid, or the vacuum regulator. You may also remove the intake manifold and clean out the ports, there might be a lot of carbon buildup. Download great diagnostics instructions from here. Hope this helps, good luck
这个答案有帮助吗?
which solenoid?
这个答案有帮助吗?
The EGR control solenoid which is inside the control box on the firewall
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 32
总计 42,021
1条评论
Have the same code P1491 EGR car runs great been sitting with not much driving for 6 years No hard shifting and is quiet only 38,000 miles but traction control light comes on too off and on. ?
由 Carrie 完成的
