跳转到主内容
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 个问题 查看全部
dropped iPhone 4 in water!
yesturday i dropped in iphone in water and immediately took it out..shook off the and out the water and put a vacuum to all the holes..that immediately cleared up the camera window and the phone would turn on....i suctioned out phone for 15 minutes and put in a tupperware container over night filled with rice. phone works fine....can make and hear calls,text,internet etc only problem is when i look at phone you can see it like 3d..certain parts on display are dark when i go to a white or black screen?? when its a colored web page i see it normal..what can i do or whats wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I would first read through our electronics water damage wiki. This will help prevent further damage to your phone. Use our guides to help you take the phone apart for cleaning and inspection. If the screen still looks odd after you've cleaned everything you may unfortunately have a damaged screen and will need to replace it. We carry the display assembly here, but hopefully cleaning things up the rest of the way will fix your issue! Good luck.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
raquel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,540
