Green lines on my display
Green lines all over my display
@itsabssam you are not telling us if they did just all of a sudden appeared or if something happened to your phone. The most common issue would be a broken display. I would start with replacing it. Use something like this video for the repair. New displays are readily available. Just do an online search and select a vendor of your choice.
If a new screen should not fix this, you will need to check the LCD connector on the board as well as the board itself for missing components etc.
这个答案有帮助吗?
First tell me lines are vertical or horizontal otherwise please change the folder
这个答案有帮助吗?
Down half of my mobile
这个答案有帮助吗?
As is the case with the rest of the phones mentioned in this thread, you almost certainly need a new screen. See @oldturkey03's answer for a link to a video showing you how to get the job done.
过去 24 小时: 3
过去 7 天: 41
过去 30 天: 167
总计 1,481
12条评论
My phone screen
showing green lining
由 suraj sharma 完成的
Please read @oldturkey03's answer above and include more information about when the problem appeared and anything that might have caused it such as being dropped, exposed to liquids, etc.
And, of course, if your phone isn't a Vivo 1907 you'll need to tell us what kind of phone you do have.
由 Jerry Wheeler 完成的
Screen get blue so that what can do
由 Fffg Rfj 完成的
@fffgrfj read the comment by Jerry Wheeler just above your question. Do what is asked in there so we can at least try to help you somewhat.
由 oldturkey03 完成的
Vivo y20a diple wait ho jata hai
由 Hifazat khan 完成的
显示更多的7条评论
