跳转到主内容
加入维修社区 - 创建账户
搭载联发科 CPU 及各项功能的中国产安卓手机。
I drop in water
I drop in water and now my phone is switch
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
I drop my phone in water
完成的
Yes I drop it how can I fix it
完成的
Charging port issus
完成的
添加一条评论
1个答案
Hello there,
You still have a chance to save the phone.
I hope you didn't try to plug in a charger to try to turn in on while charging as this can be fatal if there is inside still some water.
I highly recommend you to:
  1. Teardown the phone and take out the motherboard.
  2. Get some cheap ultrasonic device and put inside Isopropyl alcohol high % and drop the motherboard for some minutes.
  3. Dry it out for some time, clean if need all the connectors inside of the phone with IPA (isopropyl alcohol) with the help of cotton earbuds and then connect everything and try to turn it on/charging.
If you have a luck it will turn on If not the logic/motherboard needs to be inspected under microscope for some short circuits and a professional tech guy who understand microsoldering will need to step ahead and fix it or swap the motherboard from other working phone (like with broken screen).
Good Luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Muna Abdellah 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 589
