My phone is automatticaly getting switch off and on
My phone is automattically getting switch off and switch on anytime and when it start's the battery get low
@pankaj84843 I would suggest that you start off with a new battery. If that behavior continues you will have to check the charging board. Use something like this video as your guide.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
It is a not big problem, is that a setting in your phone turn off this setting to follow few step :
Open setting and open search and type schedule Power on and off .
Click on Schedule Power on and off and turn of this setting.
Finally fixed your problem ☺️
这个答案有帮助吗?
But this phone has the battery issue and service center just done some soldering to the battery and fixed the issue
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 237
总计 4,119
5条评论
I have changed battery but problem is not solved
由 uday chavhan 完成的
Battery change
由 Neeraj Vishwakarma 完成的
@neerajvish93235 is this an answer or a question?
由 oldturkey03 完成的
Want change the battery 🔋
由 jack Linden dass 完成的
@jacklindendass follow the video link provided in my answer. It will show you how to replace the battery
由 oldturkey03 完成的
