Why does my cellphone just vibrate but not turn on?
when i push power botton my cellphone does not working and open only vibrations
@lancelenar65523 when you first turn your cellphone on and it vibrates but does not display an image, it is usually because you have a failed LCD. You could try and connect your OPPO to your PC via USB cable and see if you can access it. Otherwise, I would suggest that you start off by replacing the LCD. That will at least rule it out/in as the issue.
To replace your LCD use something like this guide.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
这个答案有帮助吗?
Seconded. Although with such little information (@lancelenar65523, more details and info would be helpful), typically when the screen stays black and you have other signs of life, such as noise or vibration, it is a sign of a dead screen. That is the best diagnosis we can likely provide at this point in time.
يهتز لأن الشاشه بها عطل عندما تغير الشاشة سوف يعمل
Translation Arabic - English
It vibrates because the screen is malfunctioning, when you change the screen it will work
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 114
总计 4,462
3条评论
HP kalau mati hidupin agak susah
Translation Indonesian - English
If the cellphone turns off, it's a bit difficult to turn it on
由 Nyongki zikma 完成的
It keeps vibrating even if i dont press the power button
由 Francis Yero 完成的
@francisyero phones with a broken screen do that. It's a reminder that your screen is broken and it is begging to be replaced.
由 oldturkey03 完成的
