跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 个问题 查看全部
Top Case v3 (922-8265) on MacBook 1,1 is that possible?
MacBook Santa Rosa/Penryn Upper Case with Keyboard
I saw this Macbook part. I own a Macbook, the 2006 model, Macbook Core Duo A1181 (last 4 # of serial are: RVMN).
I saw this top case: however, a "techie" told me that the cable is different, and it won't fit on my Logic Board, because while my original topcase had a single connector, this one should have a cable with two ribbons.
Would the 922-8265 Top Case be fine on my old laptop? Eventually, may I transplant the cable from my old top case to the new one?
MacBook Santa Rosa/Penryn Upper Case with Keyboard图片
产品
$119.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Yes. Any of these top cases will work for you: Apple Part #: 922-9550, 922-8264, 922-8265, 661-5075, 661-5076
The part number you gave is for a black topcase. I have not seen this one with two cables, maybe your techie friend has been smoking something that makes him see double.
这个答案有帮助吗?
得分 5
1条评论:
So I'll get a 922-8265 as soon as I manage to get one. I took the black topcase number because... my 1,1 Macbook is black.
Then, I guess I'd just have it fitted. Thank you for your swift reply.
完成的
添加一条评论
添加你的答案
Stefano Gigante 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,485
