跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
Has my data been wiped from my iPod Classic?
I decided to see if I could get power to my Ipod Classic. I purchased a firewire charger and plugged it in. It booted up fine and seemed to have all the songs I once had.
After 30 minutes I then took it off charge to see if it might be holding charge. It turned off automatically so I put the charger back in and it booted up.
I then left it for 3 hours. When I returned the apple sign was showing and it then said plug in to restore from itunes.
Does this mean my data has been wiped off my hard drive? Or can I still retrieve it?
Best,
Gabrielle
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@gabrielleqsey for as long as you did not restore it. It seems like your iPod is just trying to go through it's usually routine as mandated by the firmware. Your files should still be on there. For now, I would go with a USB-to-Zif adapter and see if you can access the drive as an external USB drive. You could also try to place it in disk mode and see if your computer can access it. Just stay away from iTunes and make sure that iTunes is not set to an automatic restore.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabrielle Q-Sey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 28
