跳转到主内容
加入维修社区 - 创建账户
这款 Sharper Image 特技无人机发布于 2016 年,可充电,飞行范围为 150 英尺(约 45 米)。机身为黑色,配有 4 个螺旋桨。它使用 2.4GHz 发射器。该无人机无需美国联邦航空局(FAA)注册,并随附充电线和 (4) 个备用桨叶。它配有可拆卸的桨叶保护罩。
Lights flash even when turned off
The red and white status light on the drone flash even when the power switch on the drone is turned off. The flashing is brighter in the on position. The drone no longer pairs with the remote. Any ideas?
The drone suffered what seemed to be a light bump on a ceiling before malfunctioning. If nobody has a better idea, I guess I'll open it up and see if perhaps there is an antenna to reattach or some other obvious problem.
Update: Well... my boy was impatient to we had a go at it. I opened it up, moved the battery, realized there are no serviceable parts, closed it back up and... wouldn't you know, it works again but not perfectly. Now it has intermittent disconnection issues.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
sounds like something else is loose.
you need to get back in it and verify all connections are solid and clean. Remove and replace connectors.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tony Rodgers 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 490
