跳转到主内容
Repair information for the fall 2018 addition to the ASUS ROG Zephyrus lineup. This is a high-end gaming laptop in the thinnest frame for those specs at the time. Model number: GX531GS-AH76.
14 个问题 查看全部
Using different edc cable
Hey, so i have zephyrus s gx531gxr. It uses 40 pin edc cable that i have to replace. I have ordered cable from similar model (gx531gx) by mistake, and I am wondering if this cable will work on my device. The main difference is that the gx531gxr has 240hz screen and gx531gx has 144hz.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@filipklaczek for as long as the pitch of the pins is identical it should work. I did not see any crossover etc, so I would definitely give it a try. After all, if it does not work, you will know that you need to get an original.
这个答案有帮助吗?
得分 1
1条评论:
Hi @filipklaczek,
If it doesn't work the Asus part number for a GX531GXR EDP cable is 14005-02780800.
Search online using the part number to find suppliers that suit you best.
完成的
添加一条评论
添加你的答案
filip klaczek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 34
