跳转到主内容
加入维修社区 - 创建账户
The LG 5G UH850V is a 55" Smart Television designed and manufactured by the LG electronics manufacturer.
Small spot on right corner bottom after replacing back light
Hi. Just got the backlight changed by a technican, There is a small white spot on right side bottom what can be the reason. The technician says it can happen and its common. I dont buy this. Was the backlight strip he changed shorter in length ? can this be the reason. The tv backlight had 63 bulbs and the one he replaced has 60 bulbs. Pls help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@manindersin2863 that looks like backlight bleed. Commonly caused by a diffuser sheet being slightly misaligned or bend. This would require another disassembly and checking the different sheets. It is not related to the length of the replacement strips but a misalignment of the strips with the diffuser sheets.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Maninder Singh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 22
总计 466
