Can my laptop recover from this water spill?
It looks like only one part is eroded inside my MacBook Air. Is it an important part? And how do I remedy it? Thank you.
Good afternoon,
ouch, that's bad. I am gonna say that this thing is kinda screwed. First step is always to keep the laptop off and clean the corrosion.
Now, i could bore you all arvo on the reasons why this thing could be screwed, but that's not gonna fix it. So hopefully this will:
Hope that helps :)
这个答案有帮助吗?
I turned it off immediately. I appreciate the directions but your comment is making me think why even bother trying to fix it because it doesn’t sound like it can be.
@atticus26 Hmmmmm depends.
You gotta clean it before you can tell if it's worth it or not. Besides, i think everything is worth it. If it doesn't turn on, disconnect the small audio board and power on (IF THERE'S NO LIQUID ANYWHERE ELSE). generally, that board will block power to the rest of the system.
An alternative option is to look at listings on sites such as ebay and find a parts laptop. Like this one.
@atticus26 "bother trying to fix it because it doesn’t sound like it can be" sure it can be. IF you feel like you absolutely can't fix it, replacing the audio board is not a terribly complicated task MacBook Air 13" Early 2020 Audio Board Replacement
Do an online search by the Apple part number
Space Gray or Gold: 923-03672
Silver: 923-03673
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 77
