跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your Toshiba TV.
TV won't turn on ,no red light power indicator
Toshiba tv 40L310U
My Toshiba Won't turn on , power supply out put is only 3V and 5V there is no 12v out put ,
3 v reaches to standby pcb indicator light but indicator doesn't gose on ,
Please advise if someone can help me with that
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@harmankareem we don't know what you measure and specifically , where you measure. Post a couple of good images (well focused and large in size) of your boards and let us know then which connector and which pin your measured. By your symptoms and what you are saying, this sounds like a bad power supply.
在已经存在的问题里加入图片
Update (07/21/23)
@harmankareem for now, just measure all the outputs on P802. Do not try to isolate individual components yet. We don't know what turns on when, and thus it may turn into a "rabbit hole.
All the voltages are DC and you will need to have your mainboard connected when you do the measurements. Of course, be careful since the TV has to be on and there will be power on the board. Do not touch anything with your bare fingers, always use your meter probes to do the touching.
"no red light power indicator" is usually an issue with not having standby voltages.
Toshiba is a paranoid company that despises DIY'ers. There will be no help from that company and schematics etc., are very sketchy and difficult to come by. Toshiba uses their horde of attorneys to shutting down sites that share those. Just a fair warning that this can become an issue.
Update (07/21/23)
looks like your power board actually got some hot components. Could be normal but could also be an issue. Check the diodes on the bottom and the top of your power board.
Let me know if you can read the markings on the IC. Seems to be a Transistor (Power FET)
这个答案有帮助吗?
得分 0
13条评论:
Thanks for paying attention to my issues
I measured P802
DIM 3v
5vd 5v
On power supply board
110 reaches to MOSFET but not pass to main transformer
完成的
P802 measurements
PIN COD. Before connect. After connect
12V2. 0. --- 0
12V2. 0. -- 0
12V2. 0. -- 0
GND
GND
12VA. 0. -- 0
GND
12V2. 0. -- 0
GND
5V1 5.22. -- 5.22
ACD 3.6. -- 3.6
PWON. 0. -- 3.33
BLON. 0. -- 0
5V1. 5.2. -- 5.2
DIM. 0. -- 3.27
完成的
@harmankareem looks like your main board is turning your power board on but your power board does not supply the voltages.
12V2. 0. --- 0
12V2. 0. -- 0
12V2. 0. -- 0
GND
GND
12VA. 0. -- 0
GND
12V2. 0. -- 0
GND
5V1 5.22. -- 5.22
ACD 3.6. -- 3.6
PWON. 0. -- 3.33
BLON. 0. -- 0
5V1. 5.2. -- 5.2
DIM. 0. -- 3.27
The bolded ones should all show a different voltage when your TV is turned on Except PWON that actually looks right
完成的
The readings with out pushing any button, just connect p802 connector
I checked ic it look like works good,
Do you think MOSFETs having problem ?
One of those diods you show heat up is failed but the voltage doesn't reaches to transformer
完成的
@harmankareem Sure it could be a MOSFET, I just do not like to guess :-). If the Diode failed, replace that first. Those are important on your power board and can be the issue.
完成的
显示更多的8条评论
添加一条评论
添加你的答案
Harman Kareem 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 941
