跳转到主内容
加入维修社区 - 创建账户
Fitbit Charge 5 是于 2021 年 8 月 25 日发布的健身追踪器。它增加了心电图(ECG)传感器、用于测量手腕汗液的皮肤电活动(EDA)传感器,以及彩色 AMOLED 显示屏。
Is this a broken screen?
My Fitbit charge 5 screen won’t turn on. It turns on for a second and then fades back out. I tried the charger reset twice and it didn’t fix the problem. It vibrates when I tap it (sometimes) but it isn’t tracking anything according to my app.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Open your Fitbit app on your phone and see if the watch is connected. Or put it on charge then try it. If it connects take it off charge and see if it disconnects. If it does then as mentioned earlier you probably need a new battery. I have three Fitbit’s, all without a screen and I can test to see if they are on or off this way.
这个答案有帮助吗?
得分 4
添加一条评论
Hi Abbie,
I don't know enough about your Fitbit to diagnose the problem you're seeing, but I can be fairly confident that it's not a screen problem; the behavior you're describing isn't consistent with either a bad touch screen or a bad display.
I'd lean toward it being a battery issue myself, but you'll probably want someone with a bit more intimate knowledge to check in with first.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Abbie McCauley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 39
总计 2,131
