screen from motorola stays dark.
the touchscreen from motorola one (2018),It stays dark.
@josephbola the touchscreen is the part of the screen assembly which registers your touch and movement. The LCD screen is another part of the screen assembly and that is the one that shows the images. I assume you are meaning your LCD that stays dark. It is possible that this is a broken LCD, but only you know if anything happened to the phone prior to it staying dark.
Use something like this video to replace it. Screen assemblies are readily available, just do an online search for a vendor that appeals to you.
Of course, if you want to, you can always try a hard eset and see if that fixes things. Be aware that this will erase:
from your phone.
Instructions from Motorola on the reset can be found here
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 56
