Selection button not responsive
The single cup serving button is not responsive, but the 2 cup button works ok.
Is this controlled by a micro switch?
I did not do this repair until now, but I'm quite sure, there is a microswitch, which has to be replaced. Another possibility: replace the PCB. I found a used one for you at ebay.
Use this guide to open the Caffeo and have a look.
这个答案有帮助吗?
The info was useful for disassembling but there is more work to do to release the front panel. It looks like the fault will be with the pcb/ display/ switch pack.
The link to the pcb/display controller on eBay do not post to the UK.
Thanks.
Don't they ship to UK?
这个答案有帮助吗?
No they don’t ship to uk.
After looking at the inside of the machine after 2.5 years use, it looks well worn so I have decided to get a new one as I think there will be other problems ahead.
2.5 years - that's nothing! These devices live nearly forever, just like airplanes, if worn parts are replaced in time.
Another possibility: the service of Melitta itself is good and not too expensive.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 32
总计 412
