跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A51 安卓智能手机的维修指南和拆解信息。于 2020 年 1 月发布。
problems after screen replacement
Good Evening!
I replaced the mobile screen with a new one and when I turned it on it was stuck in the charging state as if it had run out of battery and the device was closed. When I pressed the power button the device turned off and the same problem occurred. Do you have any idea what could have happened?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Hi Michalis,
Which screen replacement did you do; the one with the frame or the one without? There's a significant difference between those two replacement procedures so we'll need to know which one you did so we can figure out what might have gone wrong. The iFixit guide describes the procedure for the screen without a frame.
由完成的 分享
I have Samsung A02s and went for my screen to be fixed by vendors since then the current seems not going through what is the main issue if my phone charging properly before the screen replacement
由完成的 分享
@farasiskosamwel
How long ago was it fixed by the vendors?
If only a short time e.g. 2-3 weeks, take it back to them and show them the problem.
They should have checked it was working properly before handing it back to you after the repair was done
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
It is always recommended to test your repair before applying any adhesives or putting it fully back together. I am going to assume you did this so you have easy access to the internals for testing purposes?
I have seen similar problems when the battery was not connected properly. First recommendation would be to try disconnecting and reconnecting the battery again.
If that ends in the same results, I would question the screen you bought. Here on iFixit, parts are often listed properly with exactly what models they are compatible with. For example, the screen for this model is only compatible with SM-A515F, SM-A515FM, SM-A515FN, SM-A515GN, SM-A515W, and SM-A515YN. This is notably not all the versions of this phone released in all regions throughout the world. If you bought your part here and your model of A51 is not one of these versions, the screen is incompatible and can lead to unknown errors such as you described. If you bought your screen on ebay/Amazon/etc., many vendors are not as open and/or honest with what exact models their parts are compatible with, and may sell you a part that simply does not work on your device. If you bought a screen in a frame, you have more considerations because things like antennas that may be embedded in the frame are calibrated to the frequencies in different countries and will not work and cause errors if installed onto an incorrect motherboard.
As Jerry recommended, giving us exact details on the part you bought as well as your device will help to identify this issue and possibly find an exact solution to this error.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michalis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 976
