跳转到主内容
加入维修社区 - 创建账户
VLT 1000 台式风扇拥有四片直径 30 cm 的扇叶。它由不锈钢制成,并具有 3 种速度设置。
Fan not rotating without help
Blades of my desk fan are not rotating when it is switched on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
2条评论
Kipas tidak dapat berputa
由完成的 分享
It's not rotating when on and need help to start
由完成的 分享
添加一条评论
3个答案
最有帮助的答案
How old is this fan? Is it very dirty? Often spinning blade fans collect LOTS of dust, and when that dust gets inside the motor housing it can gum up the works and cause problems like you describe (though there are other causes too).
First recommendation would be to disconnect from power, remove all the housing screws to take off the housing and carefully clean and inspect the motor and other internal components. There's a chance a good cleaning will get it working again, or at least reveal something like a blown capacitor or other failed component that could be replaced to get it working again.
这个答案有帮助吗?
得分 2
3条评论:
I already cleaned it with contact spray. I wonder if there was any sort of lubricant for the moving parts. I’m afraid that the contact might have removed the old lubricant
由完成的 分享
@samirkardahji That is a possibility, I was not aware that you had already worked on this before the problem occured. What kind of contact spray did you use? Are you sure it is safe for all of the materials and the motors? Could it have caused corrosion or a short?
由完成的 分享
It’s a quick drying cleaning solvent for electronics which removes dirt and oil. I’m not sure what kind of lubricant required for a fan, if any.
由完成的 分享
添加一条评论
Fan does not rotate
这个答案有帮助吗?
得分 1
1条评论:
First unscrew the fan blade cover , take out the fan blade , clean all the dust , then add some lubricant in bush, if the shaft is not free by hand make it free then check in power. If it isn't working yet change the capacitor of same value, fix the parts and check again.
由完成的 分享
添加一条评论
well... if the old lubricant came off that would be a problem, try wiping it off with a DAMP cloth and reapply some lubricant.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Samir Kardahji 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 39
总计 1,857
