No display no,indication light
Hi,
I have sony w800d tv and i recently replaced it's tcon board because I was having 5 times red light blinking issue. But after 3 days my tv started to blink again but when i turn off the tv then it's not turning on not even the indication light. But when i disconnect the tcon board from main board the tv turn on and when ie my old tcon board, it is also turning on but red light blinking as usual but when I connect new tcon board it is not turning on. Then removed the tcon board and turned on the tv then connect the tcon board after turning on the tv the display turns on and everything is working fine but when i turn off the tv it's not turning on. Help me guys.
Update (07/07/23)
Update (07/07/23)
It is the old tcon board
And my multimeter it's a basic one.
Update (07/07/23)
Is this ok?
3条评论
@sreeramsnair just to clarify, your model is a KDL-50W800D?
由 oldturkey03 完成的
Yes , w800D .
由 SREERAM S NAIR 完成的
I don't know but when I use my old ( not working) tcon board the tv is turning on blinking 5 times (red) but when i switch to new tcon it is not even turning on the indication light and not even the optical cable input ( a small red light used to be there). But when i turn on tv ( after removing tcon lvdt cable ) and plugging in t back after it the tv shows the display.
