跳转到主内容
The Galaxy A20e is a midrange slate Android smartphone released by Samsung in May 2019. Identifiable by model numbers SM-A202F/K.
Why is my phone overheating?
i could be playing a mobile game for 10 minutes and my screen is so hot its almost painful to touch! if someone could explain why it would be great!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@queso80563 generated images uses energy. the quicker, more complex your images need to be "drawn" and "redrawn", the more energy you need. Energy creates heat. Hence you screen heats up. The better the quality of the display, the easier it is to dissipate the heat etc. Your phone display may simply heat up because of this. Solution would be less gaming (graphic intensive).
这个答案有帮助吗?
得分 2
1条评论:
Hi @queso80563
To add to this good answer, try playing games using the phone in safe mode that way there'll be no apps running in the background, (that shouldn't be) thereby freeing up more resources that can be better utilized reducing the stress on the system
完成的
添加一条评论
添加你的答案
Queso 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 140
