跳转到主内容
加入维修社区 - 创建账户
Galaxy A14 是一款由三星于 2023 年 1 月发布的入门级 Android 智能手机,是三星 Galaxy A13 的继任者。其型号为 SM-A145(后跟版本/运营商特定字符),据此可以识别该设备。
My phone has stack when I open WiFi
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
If your Samsung Galaxy A14 freezes or becomes unresponsive when you try to open Wi-Fi, here are some steps you can follow to resolve the issue
1. Restart Your Phone
  • How to do it: Hold the power button and tap "Restart."
  • This can help clear any temporary glitches.
2. Check for Software Updates
  • Steps:
    1. Go to Settings → Software update.
    2. Tap Download and Install.
  • Keeping your phone updated can resolve bugs.
3. Clear Cache for Wi-Fi
  • Steps:
    1. Go to Settings → Apps.
    2. Tap the three-dot menu (top-right) → Show system apps.
    3. Search for Wi-Fi Direct or Wi-Fi settings.
    4. Select the app and tap Clear cache.
4. Reset Network Settings
  • Steps:
    1. Go to Settings → General management.
    2. Select Reset → Reset network settings.
    3. Confirm the action.
  • Note: You’ll need to reconnect to Wi-Fi networks afterward.
5. Safe Mode
  • Boot your phone into Safe Mode to check if a third-party app is causing the issue:
    1. Turn off your phone.
    2. Turn it back on and press the Volume Down button until the home screen appears.
    3. Check if the issue persists.
    4. If the problem goes away, uninstall recently installed apps.
6. Free Up Storage
  • Since your device has limited storage left, it might cause performance issues.
  • Steps:
    1. Go to Settings → Device care → Storage.
    2. Delete unnecessary files or apps.
7. Factory Reset
  • If none of the above steps work, a factory reset might help:
    1. Go to Settings → General management → Reset.
    2. Select Factory data reset and follow the instructions.
  • Warning: Back up your data before proceeding.
If the issue persists after these steps, it might be a hardware issue, and you should consider visiting a Samsung service center.
这个答案有帮助吗?
得分 0
添加一条评论
It has been seven days since my phone started doing this
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amiin Asker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 262
