跳转到主内容
加入维修社区 - 创建账户
The Milwaukee 2656-20 cordless ¼” hex impact driver is an 18 volt battery powered impact driver released in January 2014. The drill features 2 modes, forward and reverse, while putting out 1,500lbs of torque at 2750 RPM.
Impact driver will not turn on
When the trigger is pressed nothing happens and battery is good.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Give the troubleshooting section a try and let us know what you find.
Milwaukee Hex Impact Driver 2656-20 Troubleshooting - iFixit
You may need to open it up if you're handy with a volt/ohm meter so you can test the operation of the trigger. This guide will get you access to it for testing.
Milwaukee Hex Impact Driver 2656-20 Trigger Assembly Replacement - iFixit Repair Guide
Tell us the results of your troubleshooting and we'll see where to go from there.
这个答案有帮助吗?
得分 0
添加一条评论
Si funciona abeses puede tener arena
Spanish->English translation:
If it works sometimes, it might have sand in it.
这个答案有帮助吗?
得分 0
1条评论:
The first thing to do is open it up and clean it out; sand will destroy the gears and brushes in a short amount of time. This guide will show you how to separate the case so you can access the internals. Blow it out with compressed air and use a brush to clean out any particles that are stuck.
Milwaukee Hex Impact Driver 2656-20 Case Disassembly
If it still works intermittently after that, come back and let us know what you found when you opened it up and if it still has the same problem or if anything has changed.
Lo primero que debes hacer es abrirlo y limpiarlo; la arena destruirá los engranajes y las escobillas en poco tiempo. Esta guía te mostrará cómo separar la carcasa para que puedas acceder a los componentes internos. Sopla el interior con aire comprimido y utiliza un cepillo para eliminar cualquier partícula que haya quedado adherida.
Si, después de esto, sigue funcionando de forma intermitente, regresa y cuéntanos qué encontraste al abrirlo, y si el problema persiste o si ha cambiado algo.
完成的
添加一条评论
添加你的答案
Jose Sanchez 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 24
总计 396
