跳转到主内容
加入维修社区 - 创建账户
对于损坏的线缆的修理信息
minimum wire mm for 3 kw load
What minimum mm wire (aluminium) should be used to carry a load of 3 KW to house?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @adarshmohanty,
What voltage supply being used?
Power (watts) = voltage (Volts) x current (Amps).
You have supplied the power value (kW) and not the supply voltage value, but it is the current value (Amperes) that has to be known when determining the cable size i.e. A=P÷V e.g. 3000W ÷ 230V = 13.04A or 3000W ÷ 120V = 25A
Also the type of cable insulation is important as well.
Here's a link that may help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adarsh Mohanty 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 31
总计 546
