跳转到主内容
The Sony XBR-65X850D is a 65-inch LCD Ultra HD TV with an LED backlight and 2160p resolution. Released in 2016. Model number: XBR-65X850D.
27 个问题 查看全部
did not make it through a recent lightning storm and is totally dead
OldTurkey03: This is applebonker, but I am quite old as well. Our 65" XBR-65X850D did not make it through a recent lightning storm and is totally dead. (Luckily our 43" and our 85" are fine). The 65" has always been a bit fussy. Anyway, I have a multimeter and am willing to take the back off our 65" TV and take pictures of the boards. Are you still active on this website?
Thanks,
Steve
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@applebonker Lets do it! As you probably already know, the order of dying by electrocution for your TV is : Main board, (T-con-board if it has one), power board and finally, the panel. So, we need to check things out. Remove the back of the TV and visually check the boards. Look for anything that may have experienced some catastrophic failure. (molten, scorched and/or simply missing) Next, you need to try and turn your set on. At least plug it in. No touching of the power board with your bare fingers. It will bite :-) Use your multi meter and measure the connector where the main board plugs into the power board. Remember, it is your main board that tells the power board to turn on etc,. (simplified) but you WILL have to have STBY voltage on that connector. No STBY voltage=Power board
Post some good pictures of your boards so we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steven Mathews 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 59
