跳转到主内容
Repair guides for the 2018 version of the Samsung Galaxy A8 Android smartphone released in January 2018. Good features at a good price. Model Number SM-A530F
22 个问题 查看全部
when charging the phone says moisture detected
when i charge my my phone the phone says moisture detected,i don't live in a humid environment and i don't remember dropping my phone on some water,i tried cleaning the usb port but it didn't work. what should i do?
(sorry for my broken english)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@senopatib first try this. Turn your phone off. Then connect the charger. See if it does now charge. if you are sure that there is no moisture in the USB port and if you already cleaned it with isopropyl alcohol etc. it is time to replace the port. Of course, on this phone the port is soldered to the logic board which would require some board level soldering. If this is above your level of comfort, consider getting in touch with somebody who does board level repair. Check https://www.youtube.com/watch?v=0ZjDjt6Y... as well before working on it. This video shows you how to replace the port. It's not as easy as the video makes it seem. It'll take some experience to do the soldering.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Senopati B. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 24
总计 199
