跳转到主内容
加入维修社区 - 创建账户
适用于第 9 代 Apple iPad (Wi-Fi 版) 的维修指南、拆解和故障排除信息,有 64 GB 或 256 GB 存储空间可选。于 2021 年 9 月发布。型号为 A2602。
Charging port not working
How do I find someone to replace a charging port on an iPad 9th generation?
It was working when it fell off the bed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
First of all, if you're looking for suggestions you'll need to tell us where you're located, as this is a worldwide site and the answer will be very different depending where you are.
Until then, all I can say is you're not in a good position here. Apple did you dirty on the charging port of your iPad; not only is it attached directly to the motherboard so you can't just replace a part, but they also put it on a flex cable, making it even harder to replace. So it's going to take a fairly skilled technician to be able to do the specialized soldering required to fix your port.
You can always do a search for local repair facilities and contact them. Ask whether they have the expertise to repair your port, and what the cost is.
这个答案有帮助吗?
得分 2
添加一条评论
it stopped working then i had to fix the charging port.
这个答案有帮助吗?
得分 1
1条评论:
Same. I Suggest To get an IPAD 9 Lightning Replacement.
完成的
添加一条评论
ipad 9 no charging flex change ic change no charging
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan Frain 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 36
总计 1,801
