跳转到主内容
Support and repair information for Beats Solo3 headphones.
63 个问题 查看全部
Charge lights won't come on fully charged it plays for a second anoff
Power bars are charge lights never come on I connected to Bluetooth on my phone says it's at 100% listen to music one time but when I turn it off I could not get it to connect for more than 10 seconds The light still never come on randomly though headphones make a doot doot doot doot sound and then nothing and also randomly it pops up on my screen on my phone telling me my headphones are connected so I push on it connected to listen to music for about 10 seconds and then off again although most times when that happens it doesn't even connect tried factory reset and and all that still nothing now I can't get it to do anything
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@kevin16878 I suggest that the first thing to do, would be to change the battery. It may say fully charged, but may not hold a charge and fail under power demand. Beats Solo 3 Battery Replacement You also want to make sure that your charge connector does not have any broken, bend, or corroded pins. Clean any lint,debris with a few drops of isopropyl alcohol and a few puffs of compressed air. If you have a USB ammeter, use that to see how many amps your Headphones use when charging. It'll give you a better idea if it is. Just in case, check this guide Beats Solo 3 Charging Port Replacement
Beats Solo 3 Battery图片
指南
难度:
简单
3 - 5 minutes
Beats Solo 3 Charging Port图片
指南
难度:
困难
10 - 20 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 21
