跳转到主内容
Beats Solo 3 Battery Replacement
你所需要的
  1. Beats Solo 3 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Beats Solo 3 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Pry off the outside pane on the right side of the headphone with an opening tool.
  2. Beats Solo 3 Battery Replacement: 步骤 2 中的图像 1,1
    • You should see your battery here. It will be square with yellow packaging.
    • Be sure not to pull on the wires that are connected to the outside panel. This may cause damage to your headphones.
  3. Beats Solo 3 Battery Replacement: 步骤 3 中的图像 1,2 Beats Solo 3 Battery Replacement: 步骤 3 中的图像 2,2
    • Grasp the battery's small bundled connector, and pull gently to remove.
    • Carefully remove the top attachment from the headphones with tweezers or your fingers.
  4. Beats Solo 3 Battery Replacement: 步骤 4 中的图像 1,2 Beats Solo 3 Battery Replacement: 步骤 4 中的图像 2,2
    • Use an opening tool or a nylon spudger to carefully remove the battery. Make sure you pry upward.
    • Do not bend or puncture the lithium-ion battery.
    • Once that is removed, make sure you peel off the sticker where the battery is placed if it stuck to the battery.
    • If it is, then place it back where it belongs in the headphones.
结论
3等其他人完成本指南。
一条评论
Where too buy battery?
GSD - 回复
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 113
过去 30 天: 559
总计 11,016
