跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A22 5G 是一款由三星电子研发和制造的中端 Android 智能手机,属于 Galaxy A 系列。该手机于 2021 年 6 月 24 日首次发布。手机配备了后置三摄像头系统和 90 Hz 电子显示屏。其电池容量为 5000 mAh,比 iPhone 13 Pro 的电池大了 62%。
Sound and camera not working
So. I dropped my phone,replaced my screen (I have experience with replacing screens) and after turning the phone on I can't access my camera app or sound. When I open my camera it says "couldnt open try again" I've tried the standard fixes. Cleared cache, safe mode, factory reset, tried disabling camera. I don't have Bluetooth on I have no idea whats wrong. And I can hear sound when I plug headphones in but none without. I have taken it to a repair shop which was no help he just offered to get a new phone which I cannot afford so please help !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
10个答案
最有帮助的答案
Here is the pic hope it is clear enough. @strongbow
这个答案有帮助吗?
得分 1
添加一条评论
Hello, I have had the exact same issue before. I replaced the earpiece part and the front camera part and it worked perfectly fine. It’s damaged during transferring the old parts to the new lcd. Even though there was no visual damage.
这个答案有帮助吗?
得分 0
2条评论:
Hello. I have replaced the earpiece part and still no sound. I have also replaced the bottom speaker so was wondering what the next step would be to fix this phone
由完成的
@kuro24592 is it possible to post a good pic of the phone without without the back or plates on?
由完成的
添加一条评论
Try cleaning the back of that top board and speaker with isopropyl alcohol 99.9% and disconnect the camera and clean under both the connector on the camera and the motherboard.
这个答案有帮助吗?
得分 0
1条评论:
Thank you ill order some and try it. what do you think the issue could be?
由完成的
添加一条评论
The speaker bit in the middle at the top can be popped out with a mini flat head screwdriver and cleaned then just pop it back in the same way but make sure the two gold pins face the same way they were before removing.
这个答案有帮助吗?
得分 0
添加一条评论
I think it’s just residue left over in the connection between the board, speaker and camera as they are all gold contact connections if if they are even the slightest dirty or damaged they will not work due to an unstable connection.
这个答案有帮助吗?
得分 0
1条评论:
well the earpiece was recently replaced so shouldnt be dirty. do you think it may be a short circuit in the motherboard or just most likely dirty?
由完成的
添加一条评论
[br
@kuro24592 The ear speaker is in the wrong way lol. The two springs that are at the very top should be contacting the two metal plates on the corner of the circuit board. Lift it out rotate it 180 degrees the put it back in. When you put the board back in it should sit against the two sprung points. Also try disconnecting the cameras and re seating them as they look like they're not on properly. The area circled in the picture could be your problem. Looks like some components could be shorted.
The tip of the connector arrowed should be under the metal corner piece so when you put the board back in the tips of the speaker contact the corner plates so the ear speaker will work.
这个答案有帮助吗?
得分 0
12条评论:
Ohh well originally putting it in I had no sound so tried it the other way then left it lol
由完成的
@kuro24592 updated my answer. How did you do that to the board?
由完成的
One of the screws needed to get the board out would not come out as it was threaded but before that i had the same issues
由完成的
@kuro24592 I take it you are testing it with the back screwed on?
由完成的
Yeah I have.
由完成的
显示更多的7条评论
添加一条评论
الكمره لاتعمل القطه في الماه
这个答案有帮助吗?
得分 0
添加一条评论
Calling sound problem and back camera blur
这个答案有帮助吗?
得分 0
添加一条评论
Speaker not working
这个答案有帮助吗?
得分 0
添加一条评论
camra not wrking
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kuro 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 1,010
