跳转到主内容
Smartwatch from Samsung released in August 2020. The direct successor to the Galaxy Watch from 2018.
20 个问题 查看全部
Power Off option is popping up without the button being pressed
Not sure if this is the right forum but I'll ask anyway...
I have an issue where the Power Off option is popping up constantly on ky Galaxy Watch 3 Titanium without the button being pressed, essentially rendering the watch useless.
For a time I was still using it for activity tracking because when the screen timeout kicks in, the incessant Power Off pop up isn't an issue but then I noticed a significant increase in battery drain (Eg: Using 80% within ~ 2 hours.)
I'm about to dive in & see if I can find anything out of the ordinary; I'm thinking maybe corrosion on or around the home button pusher on the midframe but if anyone knows what is the cause of this issue &/or how to fix it, I'd be greatly appreciative.
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Tried reviewing the right, sidebar questions? At least one will have disassembly procedures that may help, with views of the interior.
完成的
添加一条评论
1个答案
@smrtwtchcllctr use these guides Samsung Galaxy Watch3 to work on it. Clean it with a high grade isopropyl alcohol (nothing less than 95%) but watch the LCD. It may stain if you get any in there. Next to cleaning it, replacing the battery may just help as well.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steven Bognar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 218
