Why is my obd2 port not communicating with my ecu
My obd2 port not communicating with my ecu what should I do?
@jasoncribb check your fuses. Commonly the OBD plug is fuse to the lighter plug. check the wiring harness for corrosion as well as fryed or loose wires. If everything checks out good then the issue is with your ECM
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 283
