My 06 just keeps blowing number 3 coil pack
Need help with y this 06 tribute keeps blowing number 3 coil pack they did put a new pcm or whatever in it before they had me pick it up still doing the same thing. Anything will help thanks.
@rodneyweav60029 that is usually an issue with the PCM. Look through the online forums for the Tribute and you will see that Mazda had issues with that form the beginning. I would suggest that you have your Mazda's OBD scanned and see if it gives you a code other then the coil pack. Make sure you have some sort of guarantee from the shop that replaced/rep[aired your Mazda since it obviously did not work.
这个答案有帮助吗?
Codes
B1342-20 (ecu internal fault)
B1349-20 (heated rear windshield relay short to battery)
B1983-20 (left front door unlock relay control circuit shorted to battery).
Keeps blowing number 6 coil pack. Starting to think the customer had a bad new pcm installed.
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 205
