跳转到主内容
Initially, the Frontier was considered a compact, but beginning with the totally redesigned model year 2005 Frontier (introduced at the 2004 North American International Auto Show), it became more mid-sized.
18 个问题 查看全部
Intermittent trouble with passenger window control switch-pls help!
My passenger window now works intermittently from both control switches, would this guide help in this situation? It's almost like the window is temperature sensitive and prefers to operate on a warm sunny day. Nissan Frontier 2004-2015 Faulty Power Window Switch Fix
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@islandboy34480 definitely a good guide to start with. Besides the switch, you do want to check the door harness and definitely your motor, since it seems to like the heat :-)
Of course, all the controls lead back to the Body Control Module, so there is a lot to be checked. I attached the part that deals with the power window control from the SM right here Power Window Control System Use that to test the components and let us know what you find out.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Island Boy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 30
