跳转到主内容
Physical game for the Nintendo DS family of systems, originally released in 2004.
4 个问题 查看全部
My dog got ahold of my Pokémon HG cartridge and broke it
My dog broke the cartridge itself but luckily I already order a new one but the main issue is that this small piece came off and I don’t know what to use to put It back on or if I have to solder
Any help would be appreciated 😊
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
@morenolimon hard to see but it appears as if the solder contacts on the IC are off. You can try a rebuild those. The IC will have to be resoldered to the board (if it is fixable) but not on the position you've marked. It goes on the other side. I marked it in blue. The position of the IC is also important so you will have to identify pin 1 on it. Take a GOOD CLEAR picture of the IC, both sides and post those with your QUESTION as well. Maybe we can see more.
这个答案有帮助吗?
得分 0
4条评论:
@oldturkey03 I took better pictures sorry about the inconvenience I tried getting as close as I can before it started to blur
完成的
@morenolimon I am sorry, but it sure looks like the contacts on the IC are a total loss. From what I see it does not look like it is repairable. If there is anything left at all, consider repairing it, but on your image, it does not look like there is.
完成的
@oldturkey03 %#*@ that sucks luckily I have the save file backed up on a usb drive thank you either way 😅
完成的
@morenolimon That Is good. At least that way it is only the cartridge that is a loss and not the data.
完成的
添加一条评论
Thats crazy :O one chip is missing, i think your dog eat it. Nintendo allready learn from this Cases, now Nintendo switch cartridge have taste, some horrible taste about children not eat them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MorenoLimon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 30
总计 276
