2000 suburban engine going into 2004 tahoe will it work
im wondering if a 2000 suburban engine will work in a 2004 tahoe
@nicholasru74706 it would have helped a bit more if you would have told us what engine size. In general yes, between 2000 and 2004 the engines should be interchangeable. There may be a few accessory brackets that may need to be changed etc. but essentially it will fit. It may not be a direct "plug and play" since you may or may not have to flash the ECU etc.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 58
