跳转到主内容
Also known as the m300, the Clip is a simple MP3 player by SanDisk released in 2007.
Why won't it charge
So I accidentally had it in the washer a while ago about a year I think. Itll turn on if I have it plugged in but once I take it off the charger even when it shows full charged battery it immediately turns off. I can use it as long as its plugged in.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@hannaharellano this sounds like either a bad battery (don't always believe what the software tells you) or corrosion from the washer incident. I'd start off by replacing the battery.You selected the m300 Sansa Clip. Let us know if that is right.
The real issue here is that there are no guides, and no videos that I can find. There is a link to an archived webpage that will be of help to you. It can be done. You got this!
Here is the disassembled view and here is write-up of opening it
While you work on your Sansa, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hannah Arellano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 383
