跳转到主内容
加入维修社区 - 创建账户
Nintendo 64 于 1996 年 6 月 23 日发布,型号为 NUS-001。它是任天堂的第一款 64 位游戏主机,也是在 Switch 发布之前唯一的 64 位游戏主机(GameCube、Wii 和 Wii U 虽然可以进行 64 位浮点运算,但并非真正的 64 位架构)。
Nintendo 64 Gradually Loses Sync
Hello. As the title states, my Nintendo 64 gradually loses sync or starts with no sync at all. The strange thing about this problem is that it affects every video connection method on the N64. I've tested composite and S-Video to no avail. I then modded my Nintendo 64 to accept RGB (mine is the NS1 revision) and the same symptoms occur on RGBs(sync on luma) and RGBs(sync on Csync). I did have a 3rd party power supply, so I checked if getting a first party power supply would work since the 3rd part power supply had irregular voltages, still to no avail. I've concluded that it might be the video DAC chip on the Nintendo 64 or a capacitor, but I'm not confident in that conclusion. It could also be that the chip is not getting enough power, but I haven't diagnosed it that far. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Can you upload a picture of the PCB inside the console? 在已经存在的问题里加入图片
完成的
Sorry I haven't seen this comment earlier. Give me a moment.
完成的
添加一条评论
1个答案
What type of TV are you using?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Javier Moe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 309
