跳转到主内容
Where to find replacement feet/parts?
Hi the feet of my Razer Blade 2020 (base) are pretty worn out and have started to come off as well. Does anyone know where to find the part? I've looked underneath the rubber strip and there seems to be some notches/clips, I doubt normal sticky feet with have a good hold.
I'd also like to replace one of the plastic covers underneath the hinge as that seems to have cracked and makes a small creaking sound when opening/closing the lid.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
I always recommend (as crazy as it sounds) going to EBAY and typing the exact model for your laptop and any part numbers for the pieces you need if you can find them. Working at a repair shop that’s the easiest way to get a good outer lcd cover replacement for a good price that matches.
这个答案有帮助吗?
得分 0
1条评论:
Hi thanks for the reply! Do you have any specific shops to recommend going to/messaging to see if they can accommodate my request? I'm not seeing any feet or bottom covers with my model RZ09-0328x. Unless I missed it!
完成的
添加一条评论
@shiroytaro I've bought feet for another computer from here before. I would call them and see what they can tell you about replacements for your Razer
这个答案有帮助吗?
得分 0
1条评论:
Hi thanks for the reply! I've actually already ordered from this website (I asked them to put up the 2020 listing!), the feet they sell seem high enough quality but they are completely flat. The Razer Blade's base cover has 2 notches sticking out for the feet to connect to, interfering with the adhesion.
完成的
添加一条评论
添加你的答案
Anthony Wong 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 30
总计 277
