跳转到主内容
加入维修社区 - 创建账户
一款联想在 2016 年推出的主打生产力的笔记本电脑,配备 15.6 英寸屏幕。P500 型号标识位于液晶显示屏边框的左下角。
Why is the screen blinking while on?
The Lenovo IdeaPad p 500 is blinking while it's been boot.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If your Lenovo IdeaPad P500 laptop screen is blinking while it's turned on, it could be due to several reasons. Here are a few possible causes and solutions:
1. Graphics driver issue: Outdated or incompatible graphics drivers can cause screen flickering. Try updating the graphics driver to the latest version provided by Lenovo or the graphics card manufacturer. You can visit the Lenovo support website or the graphics card manufacturer's website to download and install the appropriate driver for your system.
2. Display settings: Incorrect display settings can sometimes lead to screen flickering. Right-click on the desktop and select "Display settings" or "Screen resolution" to access the display settings. Make sure the resolution and refresh rate are set correctly for your display. Try adjusting these settings and see if it helps resolve the issue.
3. Malware or virus infection: Malware or viruses can interfere with your system's functioning, including the display. Run a full system scan using a reputable antivirus program to check for any malware or viruses. Quarantine or remove any threats detected during the scan.
4. Hardware issue: In some cases, screen flickering can be caused by a hardware problem. It could be a loose connection between the display panel and the motherboard, a faulty display cable, or a malfunctioning display panel. If you suspect a hardware issue, it's recommended to contact Lenovo support or take your laptop to a professional technician for further diagnosis and repair.
5. External factors: Sometimes, external factors like improper power supply, electromagnetic interference, or lighting conditions can cause screen flickering. Try using your laptop in a different location or with a different power outlet to see if the issue persists. Additionally, adjust the display's brightness settings to ensure it's not too high or too low, which could contribute to flickering.
If the screen flickering issue persists after trying these solutions, it's best to reach out to Lenovo support or a qualified technician for further assistance. They will be able to provide specific troubleshooting steps or recommend appropriate repairs based on your laptop's model and configuration.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Morris Lloyd 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 19
总计 347
