跳转到主内容
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
389 个问题 查看全部
I can only hear the typing sound
My 3ds xl has no sound except for when typing it will play the typing sound but nothing else
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try safe mode + a system format if that doesn't work. Just know safe mode will update your 3ds to 11.17, making it much harder to hack if you were planning on that.
这个答案有帮助吗?
得分 0
2条评论:
Will this work if I homebrewed it already?
完成的
that's even better, you don't have to worry about 11.17. In that case though, i'd try dumping dsp firmware before the other options. If you need a refresher, it's in rosalina under Miscellaneous options > Dump DSP firmware. No idea if it'll work, but it's worth a try
完成的
添加一条评论
添加你的答案
Justin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 27
