跳转到主内容
加入维修社区 - 创建账户
第二代 Buick Lacrosse 经过从零开始的重新设计,显著提升了品牌定位,成为 Buick 的旗舰级大型豪华轿车。
Replaced broken fob using same key not programming
I broke key fob but still had key.got a new fob put the old key in it but it won't program to the car.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If you have replaced a broken key fob with a new one but the fob is not programming to your car, there could be a few reasons for this issue. Here are some troubleshooting steps you can try:
Check the battery: Ensure that the new key fob has a fresh battery installed. A weak or dead battery can prevent the fob from properly programming to the car. Replace the battery if needed.
Follow the programming instructions: Refer to the owner's manual or contact the manufacturer or dealership for the correct programming instructions for your specific car make and model. Make sure you are following the steps correctly and in the proper order.
Reset the car's programming mode: Some vehicles require you to reset the programming mode before attempting to program a new key fob. This can usually be done by cycling the ignition on and off or using a specific sequence of buttons. Consult your owner's manual for the reset procedure.
Verify compatibility: Ensure that the new key fob is compatible with your car's make, model, and year. Key fobs are often specific to certain vehicles, and using an incompatible fob may prevent successful programming.
Also try to ask for help from https://goit.global/ph/blog/it-training-... : If you have followed all the steps correctly and the key fob still won't program, it's recommended to seek assistance from a professional locksmith or contact your car manufacturer or dealership. They will have the necessary expertise and equipment to diagnose and resolve the issue. Remember that the process of programming a key fob can vary depending on the car make and model. It's essential to consult the appropriate resources for accurate instructions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
B.Cizzle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 39
总计 956
